Hi All
Having some problems with my system following courier transport from home to my term time address. (Full time student.)
System consists of:
Soundlab DLP1R with Stanton 500II cartridge
Technics PMA700 Amplifier
Eltax Speakers
+ reasonable (if not top of the range) interconnects.
The problem I'm having is when switched to turntable mode + touch the chassis (say to lift the tonearm or change RPM setting) I can hear the contact sounds through the speakers - when the volume on the amp is on zero. Also, when playing a record I it again sounds with the volume on zero. Have tried an additional source with the amplifier and all seems to be fine. Thoughts or advice would be appreciated. System is correctly wired, turntable is grounded as it should be and so on and everything is earthed/on decent surfaces etc.
System consists of:
Eltax Speakers
