merry christmas please help. Im trying to wire up my b&ws with banna plus do i have to take of the whole binding post at the back and if so how do i do it? any help would be great
Nope, there will be some black plugs in the end of the post, you need to prise them out with a small flat bladed screwdriver. Some of the plugs have a hole down the centre and it is easir to hand twist a screw in to it and then pull.
Some types/brands of banana plug are a tight fit. You either (a) apply a little force and hope nothing breaks (b) get bog standard banana plugs fitted (the unglamorous nickel plated kind with screw-on red & black plastic covers that can be bought in Maplins).
Maybe the 'spring' part of the plug is oversized and needs a gentle crimp with pliers.
