URGENT: Chords/QED Cables in Firenze/Florence
My friend is coming from firenze, italy, in one week and im not finding a shop where he can get a good cable for me. If anyone knows any shop where he can buy good speaker cables?
Im in a lot of hurry, tnks anyway guys!
Hi Ben Law, tnks a lot. U shure they sell chord cables/QED cables on this store?
Tnks anyway!
Crocodile
38
Italian distributor of QED is Hi Fi United - hifiunited@tin.it
For Chord it's Audiotech - stefano@audiotechitaly.com
They should be able to advise of a stockist.
Tnks a lot, ive sent the an email!
Please answer me a very dumb question... I need to buy 2x speaker cable or the cables on stores like futureshops already correspond for a pair of cables?
So, if i buy in futureshop i only need to buy one unit of speaker cables and i will be able to connect both my bookshelfs into the amplifier right?
I know it sounds a stupid question but im really noob on hifi world.
BenLaw
475
7
18,895
Normally correct when buying from a shop - standard lengths will come in plastic packaging. If you mean futureshop.co.uk then if selecting custom lengths, you'll want to put the quantity to 2.
BenLaw
475
7
18,895
If you're now thinking of buying online, why don't you post a link to what you're trying to get and we can check you're definitely going to be ordering what you want.
http://www.futureshop.co.uk/chord-carnival-silverscreen-speaker-cable-p-1133.html
I need two of these right?
simonlewis
590
That cable is quite expensive imo, i just had a play & said i wanted 2.5 meters, banana's at amp end times two = £38.46
