Hello everybody,
My name is Filippo and I’m writing from Italy; after searching for a while (and without finding many solutions, like the topping m50 which isnt in production anymore) I decided to ask for help from who knows better and more than me 🙂
In my actual set up my FIIO M9 (and its 512gb microsd) is my main source - coax to Burton composer 3xp and then to my preamp - and I’m really happy about how everything sounds….BUT since FIIO’s app is a real pain in the ass (keeps losing wifi, doesn’t really sync playlists, playlists can only be done thru the M9 etc etc) its not really handy to control music since instead doing it from the app and my phone it ends up that I have to stand up and operate directly from the M9.
Basically Im looking for something (how would you call it?Player?Transporter?) to play ONLY my local files (not interested in streaming from tidal, Spotify etc etc) without having to use my macbook pro to access the music in my hd and to be able to control it with an app from my phone (android).
This “something” should have an usb IN to plug my 4tb hd (where all my music is), a usb OUT and coax OUT to feed the Burson Composer 3xp and a decent, usable app for android (a bonus would be some integration with my macboob pro to, for example, work on my playlists)
What it shouldn’t have is a built in DAC and other stuff related to streaming that I don’t need so to keep the budget as human as possible.
Any suggestion??
Of course whatever ill end up doing or adding it doesn’t have to affect the audio quality I have now ; if anything, I would like to improve it, infact since the M9 act as source and is battery powered i have really no noise, interferences or hum of any kind
Looking forward to hear what your suggestions will be and if you need any further info please do not hesitate to ask.
Tnx in advance to anybody who will help 🙂
Ciao e grazie,
Filippo.
Any suggestion??
Ciao e grazie,
Filippo.
