I have a Creek Evolution C.D. Player , I listen through Alessandro Headphones via Graham Slee Headphone Amp. What C.D. Player would you recommend to Upgrade to.Thanks.
XTZ offer a home trial period, so you can compare it side-by-side with your Creek at home.
As for the Audiolab, take the CDP and Head-amp to your local dealer and compare. Or purchase from an online store that you know for sure will refund you if you're not happy with the sound.
Although the new Audiolab CDP/DAC is brilliant by all accounts, I'm not sure how the synergy will pan out with the Creek. TBH, for a budget you'll be hard pushed to better the Creek Evo CDP.
Maybe it doesn't quite meet your preference for new, but there are some good deals around on the Cyrus CD8se reprocessed (these should come with full 2yr warranty) and ex-demo models. Cheapest I have seen is about £900 though.
You should check relevant posts on here as there have been some teething problems but hopefully sorted now.
