Hi all,
I've just got myself a UnitiQute. It's lovely.
The dealer told me that I could connect speakers via the usual banana plugs. This I have done - and the sound comes out as I would expect. I've not got the greatest speakers (yet! ) but it all sounded good to me.
But.... the connections are not as tight as I would expect them - particularly the black '-' connections, they have some 'movement' in and out. There is no tension on the speaker cable - there's plenty of give.
The plugs are simple £10 CambridgeAudio plugs onto Chord cable. I did it myself but the plugs and cable are firmly together - this is not the cause.
Was the dealer correct in telling me to use these usual connectors - or are there special Naim connections? ( this is my first naim system but I'm aware of this brand's historical 'eccentricities' re connections ).
I don't want to break it in the first week!
thanks in anticipation of your help/advice
