TV Screen cleaner
JanHruska
Hi All,
I have recently bought the Sony KD49X8505 and was wondering what would be best to clean the screen with ?. I see that you can buy all sorts of tv cleaners that come with a spray and a cloth - but are these the best thing to use ? and if so, which are the ones you would recommend ?. All suggestions welcome.
Many Thanks,
Jan.
relocated
74
Somewhere in your product documentation/online, Sony will make their recommendation known to you.
It is likely to be: use a clean, dry, microfibre cloth to keep it clean; if you need better than that - a slightly damp microfibre cloth to gently remove more persistant marks. Whatever claims are made, I wouldn't use any sort of 'cleaner' on any screen.
