tv and amp sound
mayz
hello to all.need help if pos.i have a 40 in technika led tv.model no:LED 40 E271 which iwant to plug into my kenwood amp model no:KA-1030 so that tv sound comes out of my speakers but i dont know what sockets or leads to buy and use.any help would be great many thanks.mayz
You're a bit limited to connections both on the TV and the amp, but if you connect from to the stereo jack on the TV marked 'earphone' to the Aux socket on the amp, you just need a simple cable. Kenable item 03575 or similar will do the trick. You may even find one in Poundland (though it may not be long enough..)
