TV aerial
Martin100
18
Hiya can any body please tell me if i can some how,
1. TV coax direct into Sony AV Receiver.
2. The above into the digital input of the AV Receiver.
3. All the above then upscaled.
4. If poss were to put what.
AV Receiver Sony STR-DA5200ES
With thanks
Martin :)
chudleighpaul
129
Why would you want to connect a TV aerial co ax to an AV receiver? The only aerial co ax that should be connected is an FM radio aerial.
The TV aerial should be connected direct to the TV or PVR.
Alantiggger
274
33
18,920
The fellow may have been reading somewher that the AV Receiver can upscale the likes of DVD and Blu Ray pictures and got a little mixed-up ?
The bottom line is that the fellow asked for a bit of help.... which your good self did give :clap:
I am not sure if this is possible. But I remember reading something online, maybe on Maplin's website. Try them.
Let us know if you were able to do this!
chudleighpaul
129
The only way it would be possible to connect a TV aerial direct to an AV receiver is if that receiver contained a TV tuner. As far as I am aware no receiver sold in this country has a TV tuner.
