tv aerial
hi i am after supplying 5 tv's with aerials, can i use 1 aerial with a booster or will signal still drop. if this wont work can anyone recommend other options thanks.
Alot depends on the cable run length required ect. You may find a picture quality drop with 5 sets on
even with a 6 output amp/distributor Even type and size of tv have a baring on the output qual..
Suggest you use Ct125 coax as well, rather than Ct100 as your signal deterioration will be much less.
Edited: no trading, please - Mods
