I'm doing up my living room and replacing an old coal fire with a gas fire. I'm planning to wall mount the new tv screen above the fire. Probably the fire won't be used much since we have central heating. Is this a bad idea? Would we need a mantle piece to help protect the screen?
Innevitably, the screen is going to be quite high up. We may be able to choose a fire place that is shorter but this is not my wifes preference. How high is too high for a screen?
If the new screen has a freeview receiver built in, do I connect the aerial lead directly to it, or can I go through an amplifier receiver? If it does have to go direct to the TV, how do I set things up so that I can record freeview? I presume that the hdmi out from the amp means no signal can return to the amp. Do I need a second hdmi cable to return the freeview signal to the amp?
