I hope you are all keeping well.
I've recently made a few changes to my system and have now detected a hum coming through the phono stage input at a fairly low volume.
I run a rega elex-r amp, it's such a good amp, with b&w 706s2 speakers, which I'm really happy with. In addition, I've got a project carbon turntable, which is fine and would like to change at some point. I've recently bought a set of chord c line rca cables to connect the turntable to the amp. The cables are an improvement but its introduced a hum. I think it is interfering with my bluesound node 2i. When I turn the node off it massively reduces. In addition, if I keep the node on and go back to my normal rca cable the hum also massively reduces.
Can anyone please help advise why this is happening. Is the Chord cable faulty, should the additional quality cable produce this and do I just need to further the node from the system.
I'm at a bit of a loss and would appreciate your thoughts.
Many thanks
Phil
Many thanks
Phil
