- Aug 10, 2019
- 2,556
- 5
- 0
My system comprises a 1985 Linn Sondek LP12 with Basik Plus arm and Linn K9 cartridge, a NAD 3120 integrated amplifier from 1986, Celestion 3 speakers from 1989, a Marantz SA7001 CD player. I also have a BR900CD digital recorder/mixer (I play the drums which feed into this) and a pair of M-Audio Studiophile BX-8A monitors mounted on Heybrook speaker stands.
I have a dilemma. I can either buy a new Technics SL1210/origin Live RB250 arm/Dynavector DV10X5 or get my LP12 serviced and updated. I've been told the Technics combo will be miles ahead of the Linn LP12.
I want a really professional sound from vinyl; pitch stability is important as I play the drums and timing is critical. I want the sound from vinyl to sound like BBC Radio 1 or 2 FM when they used to play vinyl, and as they used Technics SP10 perhaps this is the way to go rather than the LP12? I also want the rest of my system to sound 'professional' like BBC FM sound quality on Radio 1 or 2.
Would the Technics Deck hold its value well?
Secondly I have budget of £1000 to upgrade my ageing NAD 3120 and Celestion 3 speakers; what about the Yamaha A-S500 with B&W 685 speakers? would these work well together and give me what i'm looking for?
I need speaker stands, equipment rack (to go in my living room), speaker cable too; and ideas for best sound?
Lastly has anyone ever heard the Technics SL1210/Origin Live RB250/Dynavector DV10X5 against the LP12?
Also could anyone recommend a good dealer in Southport area for the above; for Linn it has to be Chris Brooks in Warrington but for the rest of the gear?
The modified Technics would be bought from Sound HIFI in Devon. The cartridge could also be the Audio Technica moving coil AT-F3/III, but i heard the 10X5 back in 1979 on a Sansui SR222 and it sounded fabulous then.
Kind Regards,
Kind Regards,
