Al ears
as 12th Monkey says I have noticed a distinct improvement in my speakers / room interaction since fitting the isolators.
What did you actually do, if you don't mind me asking?as 12th Monkey says I have noticed a distinct improvement in my speakers / room interaction since fitting the isolators.
I think the vibrations you are thinking of are not intended to leave the speakers, other than via the drive units. I've had no bad experiences whatever in trying to dampen out vibration anywhere in my system.
IN terms of which is better, I don't know. I have them doing different things, really. But SolidAir's stuff is definitely rather cheaper, like for like.
You mean occupation as opposed to posting on here on my 65th birthday?What did you actually do, if you don't mind me asking?
Some of the standmount speakers I had came with stands to which they were physically clamped.my asking of this question (op) was based on my experience with the b&w 601 s2 loudspeakers i had. initially had them with blu-tack between speaker stand and speaker and the sound was blurred / fuzzy (?) with a bumpy one note bass...
this puzzled me as this is exactly how the hifi shop instructed me to set them up...
(i was a total beginner to hifi then 20 years ago and just bought them blind as they fitted my limited budget as a poor student).
after reading some (free) advice from russ andrews as regards to speaker stands etc i removed the blu-tach and just placed them flat on the speaker stands and the sound improved - clearer with better separation and no more lumpy bass !
i put this down to the fact that the cheap / poorly braced cabinets were not damping the vibrations from the drive units properly hence they needed to be released, instead of being "trapped", like they were when using the blu-tach.
i must say the kef ls50's i had were not affected at all as regards to the speaker stands or what was placed under neath them but they are, in my opinion, a properly braced well made cabinet.
Why do you ask?
Depending on the maker some are better attached this way and yet some like my sealed-box EB2's are better isolated on my Partington Dreadnought stands.
I guess it's all down to personal preference.
Why do you ask?
Yes happy birthday!......here on my 65th birthday
Well there were a few here before me... 🙂Yes happy birthday!
Al ears, a name that, to me, has always been here on this forum.
We'll let him answer that. He actually asked what I do not what I use, that has been previously stated.i think he is referring to which "isolators" you use - no mention of them in your kit / system details !
See post #11 on this thread.....i think he is referring to which "isolators" you use - no mention of them in your kit / system details !
Slainte, currently listening to my newly acquired Surrealistic Pillow album with a nice Rioja.Yes happy birthday!
