spockfish said:Hesitating to answer this *biggrin*, but yeah I've got one of them in high-res: Damn the Torpedoes.
And yeah, I'm one of those idiots who thinks that (some) high res recordings are worth it, including this one.
Tip: the latest Björk in high-res. Absolute stunning record.
spockfish said:Tip: the latest Björk in high-res. Absolute stunning record.
davedotco said:spockfish said:Hesitating to answer this *biggrin*, but yeah I've got one of them in high-res: Damn the Torpedoes.
I do not think that anyone with any knowledge of of this issue will deny that there is a difference between some hi-res releases and their CD standard counterparts, the question is what is causing the difference.
My view is that if the hi-res releases have the benefit of better mastering, then they will sound better, but to me this is a simple con, and implies that CD quality releases are poorly mastered, either by a general lack of interest by the record companies or even deliberate, so they can sell you the 'better' hi-res version for more money.
If you are at all technical, you can prove this for yourself.
Take a great sounding hi-res download and use your computer to downsample to 16/44.1, then compare the two, ideally using the ABX function in Foobar. No issues of different masters, the only difference is the 'resolution'.
24/96 vs 16/44.1, a real comparison.
lpv said:davedotco said:spockfish said:Hesitating to answer this *biggrin*, but yeah I've got one of them in high-res: Damn the Torpedoes.
Did that. No difference on any of my headphones.
... now you Mr Pitty? What's going on? Are they too old to be ashamed? He can't hear his own farts but just like in HD music, he can feel it.
fr0g said:I do not believe for one second that there is a human being on this planet who can tell the difference between a hires track and the same track downsampled to "CD quality"
chebby said:fr0g said:I do not believe for one second that there is a human being on this planet who can tell the difference between a hires track and the same track downsampled to "CD quality"
Is there a human being on this planet who is not flattered that someone 'out there' is making something for their special hearing abilities?
"Yes it will be expensive - quality always is - but at least someone, finally, recognises the naturally gifted minority like me!"
manicm said:So, anyone then care to explain my downsample in my earlier post here? I had to do it and the original sounded a bit clearer definitely.
steve_1979 said:manicm said:So, anyone then care to explain my downsample in my earlier post here? I had to do it and the original sounded a bit clearer definitely.
On the few occasions when I've tried downsampling hi-rez audio I've used Audacity (which uses LAME) and the resulting file always sounds identical to the original.
fr0g said:steve_1979 said:manicm said:So, anyone then care to explain my downsample in my earlier post here? I had to do it and the original sounded a bit clearer definitely.
Assuming you mean to downsample to 16/44.1 then LAME has nothing to do with it as it is a codec to create MP3s.
steve_1979 said:fr0g said:steve_1979 said:manicm said:So, anyone then care to explain my downsample in my earlier post here? I had to do it and the original sounded a bit clearer definitely.
Of course! Silly me, I wasn't thinking.
manicm said:If any of you bothered to read properly I used MediaMonkey to downsample a 44/24 album to 44/16, and the latter came out second best sonically.
cheeseboy said:manicm said:If any of you bothered to read properly I used MediaMonkey to downsample a 44/24 album to 44/16, and the latter came out second best sonically.
two things... was the downsampled track in ALAC (as you said it was for an ipod) and did you try playing back in foobars abx system, or did you test the tracks knowing which one was which?
manicm said:No, the hires purchased album was in FLAC, which I subsequently unpacked to WAV using Flac Front-end, and then used MediaMonkey to downsample.
manicm said:I did not do blind testing. But maybe I will using foobar if a trial version is available.
manicm said:I downsampled to WAV format, 16/44. I'll give foobar a go.
