Hi jef...Good to hear your experience of the XTZ...
You mentioned 'difficult' speakers..... I wondered what speakers you were using?
In the UK there is the option to demo at home for much longer...Did you not have this facility or maybe you borrowed the amp from someone else?
jef_dk3 said:Hi there fellas.
Surfing around I found this thread. I'm in search of an integrated amp these days, and, among others, I have tried the XTZ A100D3 at home for a couple of days (I'm currently demoing a Vincent SV-236MK and a Naim Nait XS).
Don't be fooled guys, there is no way you can find this sound and these features unless you spend considerably bigger money. The build quality is out of this world (for the money) and the sound is amazing. Total control, really tight low end and highs that won't hiss no matter where the volume is. I also found the built-in dac really decent and the overall sound to be that of a really more expensive amp. It managed to drive my difficult speakers with ease.
Now, what I didn't find particularly effective is that Class A thing. The only thing that happens when you switch to class A is the amp running hot within minutes. I tried hard to hear a difference, but didn't manage to, at least not within the two days I had it home.
One thing I did miss was a second set of speaker inputs to enable biwire. But that's minor I suppose if you take a look at the price again.
I will most probably not buy it since I decided to go up in money for my amp, but if my limit was 1000 euros there would not be a second thought about which amp to buy.
Hope that helps
