The Rega RP3 and RP6 slight cosmetic seconds
BigH
97
bigfish786 said:
For all those interested, there are a few on eBay again.
Pick up a bargain while you can.
£349 for the RP3 and £649 for the RP6
Are they just cosmetic defeats though? Some RP3s are £299.
bigfish786
Moderator
Jan 29, 2013
553
351
19,270
I believe so, brand new, with warranty, from rega dealers.
This usually happens a few times a year.
The rp6 is very tempting with ttpsu included.
add a cart of your choice and you are sorted.
BigH
97
OK thanks, only heard a few people having wonky platters on those, but I suppose you can get that on the grade A ones.
Its certainly puts the used prices into perspective, who would buy a 15-20 year old RP3 for £250-£300 when when you can get a new one for that price?
Frank Harvey
567
Because end of line deals are limited.
Although, there are no 15-20 year old RP3s out there. Planar 3s maybe...
If it's that old then it's a Planar 3 not a RP3, and yes it is overpriced unless it includes a good cartridge.
stevebrock
183
New Planar 6 coming ???
I had a white RP6 seconds - couldnt see anything wrong with it - bargain if you ask me
It has been quite obvious that the Rega namings is confusing a lot of people
There is a big difference between Planar and RP versions, and indeed tonearms they have attached.
Be wary folks.
BigH
97
Yes I meant Rega Planar 3. Yes its confusing going from Planar 3 to RP3 and now to Planar 3 again.
Most come with cheap cartridge like the AT95E, Stanton ? and Linn K9 or nothing.
ASK THE COMMUNITY
