Cartridge suggestion
Ivek
17
Dear members.
Among other things, I own a Rega RP3 turntable, Rega Elex-R amplifier and Dynaudio DM 3/7 speakers. The turntable had an Elys 2 cartridge installed, which I replaced with an Ortofon OM 10 because of the sibilance and inner groove distortion that were significant with the Elys 2 cartridge. With Ortofon OM 10, inner groove distortion and sibilance were significantly reduced. Then I installed an Audio Technica AT VM 540 cartridge, and the sibilance and IGD disappeared completely. Recently, a friend assured me that the Audio Technica AT VM 540 is not compatible with my Rega system. On the one hand, due to the low load capacitance and low output voltage, it is not compatible with the amplifier. On the other hand, due to its low weight and high height, it is not compatible with a turntable. He suggested the Ortofon 2MR series, which is optimised for Rega. He even gave me an Ortofon 2MR bronze that he no longer needs. Now I am left confused, because I am very satisfied with the Audio Technica. So I have a few questions
1. Should I be concerned about low voltage and low load capacitance?
2. Will I hear inner groove distortion and sibilance with the Ortofon 2MR bronze?
3. Is Ortofon a good tracker?
Some will probably tell me to mount the Ortofon, so I can tell which cartridge is better. And they are right. Although I know how to mount it, I am not skilled at it, and it will take a long time. So please answer me before I embark on this adventure.
Thanks for your answers
OM10 - Upgrade the stylus - Stylus 20/30/40
2MR are reduced height for arms with no VTA adjustment Eg Rega
voltage - adjust gain on your phono stage
capacitance - adjust on your phono stage
cap as stated per manuf + internal cap of your phono stage + cap of your cable = total 100/450 Pf normal range
if you adjust zenith / VTA / Azimiuth no IGD
Rega arms all above are fixed & cant be adjusted
Famous for great tracking and almost every record ever cut used ortofon cutting heads on the cutting lathe
4/ used several Rega decks over the decades , but they require lots of work to set up correctly
if you want a easy life
Technics remove from box / play records / leave to your children
View: https://www.youtube.com/watch?v=wAj22g8MWkw
Dear members.
It doesn't have low voltage.
Rega turntables need shims to raise the tonearm height for most 'normal ' cartridges .
Cannot speak about tracking but don't see any reported issues.
If you are satisfied with the AT then keep it.
If you need help with accurate setup see a dealer.
Just my opinion.
Rega arms can be adjusted.
You assume he is actually using a phono stage with adjustment, wrong!
From what he says he is simply using the amps phono stage.
The Ortofon has a slightly higher output voltage but you probably wouldn't notice it.
Capacitance is irrelevant when it comes between the two cartridges in question.
The only technical issue is the relative height difference between the two cartridges .
2M Recommended load capacitance
150 – 300 pF
OM Recommended load capacitance
200 – 500 pF
Incorrect loading Pf will affect the Sound
Phono cartridge is a minature electrical generator and correct loading the the phono stage can have big changes to sound
The cartridge + cable + preamp input form a resonant LC circuit (inductance of the cartridge + total load capacitance).
150-500pf Total PF
If phono stage is fixed PF Loading plugs of different values can be used
Too much capacitance will boost the upper treble then causes a sharp roll-off
️ Sound becomes bright, edgy, spitty, then very dull above the resonance point 18-22kz
️ can also cause very big Peaks around 10–15 kHz
Too little capacitance will reduce treble energy
️ Sound becomes soft, muted, lacking detail
MI moving iron cartridges Pf has very little affect Grado , Soundsmith , Nagaoka
Reactions: Rui
Dear members.
Your friend was talking out their backside.
The Rega and the AT would be a good match. I used to use a P3 with a 440-MLa. One of the best vinyl partnerships I've had. The 540 is not different which I use with a Cambridge Alva ST deck today.
150 – 300 pF
200 – 500 pF
150-500pf Total PF
View attachment 10542View attachment 10543
it´s only a pitty they are worth ,nothing, they sound not as good as the cheapest cartridge from AT, 79 to 95
Correctly installed & loaded they both sound very good. Used OM40 Super & 2M Black for years
So you never tried a real cartridge and stylus ,i have either than the 2m black ,others a lot better but i thought ,if it is so good let me buy one for my old SL-1310mk II but it sounded worst than the one i had or several i have of buying better cartridges for new turntables or my father bought them and the one with the turntable would be stored , so now i tried the 207C this in 2017 as the others are hard to find and 30€ new stylus are britle and sometimes not even a stylus as it was supposed to be, is there , i have a binocular lenses for my work in Agriculture but can see the stylus tip as if they were 2 meters high, any badly done work is seen at perfect size, bought some around 100€ and were well built and of good fabric material ,almost sounds as the original ones, this new wave of cartridges are a technology so ancient and expensive at the same time, and the 2m black at least three i heard from other brands are a lot better can give the example of the low output Grado prestige Gold III as the prestige gold was already known to be good as Ortofon in the 90´s were really good , or since 77 the first time i had one at home in the 77 tangential turntable from Revox B series, inside the box we put on top of the record, all is Ortofon made, most call linear tracking to tangential turntables but there are S-shaped arm turntables with linear tracking, a photo celular reading optic in the cartridge as in the full automatic technics turntables all had it, as it is known by T4P ,Technics own system adopted by several brands. and correctly installed are all ,or you think you´re the first to know it, i already made it since i was 12 and there were better devices to put the stylus in the perfect spot on the record , anti-skating more in new said to be good arms like one from Rega that when i saw it, i thought they were joking with me, a bit of trashy built arm without any quality or the anti-skating system will not last 10 years much less over 50 years, and also don´t think the value you insert is correct as with the use of the arm will not be acurate but they sell all for one to install more or less correct the cartridge position, like a preassure measure and two spots on the record to be acurate but which records does they refer as each record is diferentely built and from label to label not all are the same, i heard already someone with a Rega turntable complain of a Lp that as so much time in each side, why didn´t they released it in two records, this guy a Youtuber should think twice before making a sad statment for all in the world to see how he doesn´t have a clue about records or turntables and to be more acurate there are 3 measures to be done not only two but today we return to cheap 60´s turntables as there were already several times better turntables that work today more acurate than anyother you buy till 5.000€.
You say they sound is very good ,imagine if you had a aceptable quality cartridge and stylus, as they, Ortofon sound cheap and the increasing of high frequencies is not what makes a cartridge good, buy a equalizer and you´ll have endless possibilities of having the sound of all cartridges with a cheap quality around the 2m black that is expensive and not even good as the second cheapest Audio-technica with the cheapest stylus from 1979 to 1983, this period is while i had in use one, not going to refer all years it was sold ,maybe the most sold cartridge and stylus in the world as it was cheap and quality wise dont know which cartridge would have that higher quality. To end i just want to say that nothing sold today to read vinyl is related with old evolved turntables ,cartridges and stylus, and in youtube test were made to see how ridiculous are a new Rega turntable or Pro-Ject debut against a cheap technics sold in early 90´s around what today is 100€, fully automatic , that with more than 30 years of use is more acurate and specifications wise correct than a Pro-Ject Debut bought three days earlier that not even is close to the brands specifications, new .What about in 30 years will be better? if not even new works as it is supposed, maybe the reason why some say the cd sounds better as i had many expensive cd players and none is better than a record sound with all it´s defects, and if you buy a expensive turntable with a expensive amplifier that comes with tone controls ,if they are there is to correct the sound as not all have a studio quality system at home, or dedicated listening room with perfect isolation , panels to deflect sound ,bass in B&W 800 series are needing sub-woofers , it´s a laugh they have the best bass i heard in a home system , how crappy needs to be a system to not have bass release in the 800 series from B&W, good speakers in my opinion or the so talked about in the last 10 years Focal emerged from a old brand but they have the grande Utopia that sounds amazing with all it´s variations.
Dear members.
I appreciate it's been a while and you've had a few responses but my two cents:
the VM540 (ML? SH?) should be set with maximum capacitance of 150pF, the Elex-R has 220pF - add the tonearm cable and RCA you are over double that easily.
That said, in-between phono stages, during the several I have changed in the last yeat, I did occasionally play the VM540ML, through the Elex-R phono. I am not an analytical listener but the few records I played were OK - I can't remember any dramatic issue with treble. It certainly sounds much better properly "loaded". In fact the best it sounded was with a Simaudio Moon 110LP set at 0pF.
Bottom line, maybe pay attention to any harshness in the treble, but if you don't hear any, enjoy!
P.s. I also have some hearing loss, and anything above 10.5/11khz is irrelevant for me - which is maybe why I didn't hear any harshness haha
I have a 2MR Red on my P3, which replaced an Elys2. It was an improvement in sound, tracks very well with no IGD, and leaves me to get on with enjoying my LPs. I've owned all sorts over the years, including a Sumiko Evo III Blue Point Special on a Michell TecnoArm/TecnoDec, and while I won't pretend this sounds as good as that, it's no slouch for the money. I'd say the 2MR range is a good option for the P3.
The MR range was specifically designed for Rega arms but I guess they would work just as well on any others with VTA adjustment.
Still think the Blue or Bronze is a better buy as I couldn't get on with the Red, but that's just me.
I an sure many find it adequate.
For other arms I would just use the standard 2M cartridges. Apart from the body height, they are exactly the same, and the styli are the same ones. I certainly intend to go for the Blue stylus when I can afford to (and of course that won't require changing the cart), but I do quite like the Red.
No problem, as with all hifi it's each to their own....
Hello everyone. Thanks for your posts and suggestions.
In my opinion, the Audio Technica at-VM 540ML is excellent. I have used it with and without spacers. I did not see the need for them. Compared to the Elys 2 cartridge that came with the turntable, there is a noticeable difference in sound quality. There is no more hiss, sibilance and inner groove distortion. But on some recordings, I hear brightness and sharpness. I have now replaced it with an Ortofon 2MR Bronze. I have listened to classical, jazz and pop records. Although I have not listened to it much, I can say that the Bronze is a more balanced cartridge that has a better sound image. Instruments are better separated and vocals are much clearer. I have not listened to records with IGD, so I cannot make a comparison. I have a feeling that Bronze is more sensitive to surface noise. I need to let it break-in and listen to more records of different quality. Of course I will share my experiences.
Reactions: nopiano
2M range Red / Blue / Bronze / Black / LVB / Mono / 78
2M - Standard turntables
2MR - Rega - reduced body height
2M Concorde Music - Technics plug in with integrated headhell
2M Pre-Mounted - With Headshell
2M Verso Thorens bottom screw fixing
2M Mono
2M Mono 78
2M Mono
2M Mono 78
It’s remarkable we have such a range today, when forty years ago LPs almost vanished. And that’s just their MMs. There are at least two ranges of MC plus the top of the range named models!
With a history dating back to 1918, Ortofon has been developing phono cartridges since 1948 and since then has manufactured over 300 different cartridge models.
Almost Every record ever cut on a Lathe used ortofon cutting heads
Not to mention Ortofons vast range of DJ cartridges standard globally in Nightclubs , Hip Hop , Raves
Ortofon historically since 1948 have shipped more than 40million cartridges
half a million + cartridges per year
Reactions: nopiano
