- Jun 15, 2011
- 31
- 0
- 0
hoopsontoast said:Wide left feild choice, how about the Eclipse speakers?
http://www.eclipse-td.net/
http://www.whathifi.com/eclipse-td
Not heard them though. Should be good at soundstage, IME with full-range-drivers.
krolikgena said:And no comments about AE1 MKII SE.. does somebody have them at all on the forum??
AEJim said:krolikgena said:And no comments about AE1 MKII SE.. does somebody have them at all on the forum??
I do! I'm not sure this counts though. :
Actually I think the new WHF Ed has a pair (non-SE spec) unless he's moved on. Technically speaking they are now discontinued, though there may still be a few around at dealers as this was only recent.
krolikgena said:Can you tell why they were discontinued? and how they compare to the relatively new Reference 1?
FrankHarveyHiFi said:Unfortunately it is hard to recommend a distance because rooms are different. The wall behind the speaker could be stud partition, plasterboard with a gap then brick/breeze block, solid brick, brick cavity, double brick, stone, breeze block etc etc. All these will have a different effect on a speaker/subwoofer's in room performance. The type of flooring can also affect things.
You could be talking inches or feet, regardless of where the port is situated.
FrankHarveyHiFi said:Spendor SA1 - Quite an unassuming sound, pretty neutral, nicely detailed, not greatly extended bass due to its small sealed cabinet, but quite a natural, even bass, if a little light compared to the rest of the group.
B&W PM1 - Beautifully open treble and amazingly detailed. Quite a lot of bass for such a small standmount with a small bass driver, but like all mini monitors, you're not going to get gig levels with bass heavy material. Lovely build and finish. They like a bit of space to work well in, despite being front ported.
PMC DB1 - One of the lighter (weight) models here, so it may not feel in the same quality as the likes f the LS50 or PM1. One of the livelier performers of the group that still sounds exciting at lower volumes. Can sound a little boxy in comparison to others in the group.
Kef LS50 - More akin to listening to headphones with their ability to stop/start. Great detail and projection. Bass isn't the deepest here, but what they do have is pretty solid. Like the PM1's, they do like a little bit of space to stretch their legs.
Acoustic Energy AE1 MKIII - I have heard the MkIII's but it was quite a while ago, so it would be unfair of me to comment. I did hear the Classic version more recently.
ATC SCM11 - Sounds a little restrained in the top end compared to some of the other models here, but they posses the largest bass driver of the group and would probably win out on SPL. Again, pretty neutral, with a nice even bass due to a sealed cabinet.
All of these models need capable amplification to get the best from them, the level of which varies depending on the model. The PM1's, LS50's, and DB1's have greater presence than the other speakers, which tend to lack a little in comparison at lower volumes.
BigH said:David, I have brick cavity walls, where the speakers will be less than 1 feet away, not near corners though, will the KEF LS50 and DB1is be alright in that situation, floor is wooden floorboards covered with carpet, room is 17 x11 feet.
alchemist 1 said:What puzzles me B&W rec. a min of 500mm,but it's classed as a bookshelf speaker.
Other speaker manufactures seem guilty of the same description. :read:
alchemist 1 said:Which of these give the warmer tonal presentation. ?
Warmer, mmm...., weight...gravitasFrankHarveyHiFi said:alchemist 1 said:Which of these give the warmer tonal presentation. ?
Define 'warmer' 🙂
Some will feel that warmer is just a nice full low end (more bass), others a fuller midrange. Others might feel that warmer means that the treble isn't too prominent which brings the bass and lower mid more to the fore, or even just a dull sounding speaker. Can a speaker sound warm and have a strong upper mid/lower HF presence?
I'd say it'd be between the DB1i, PM1, with the LS50 just a little behind. The PM1's have a strong bass despite their small driver, so will sound warm to some, while the DB1i has a warm midrange (to me), so despite its brighter treble it is an easy listen, but can lack attack because of this. The LS50's can sound warm depending on positioning and if no bungs are used.
I've never found the SA1 to be warm, more neutral with a lean bass, and the SCM11 can come across as warm with 'the right material' due to its rolled off treble.
emberins said:Sorry for reviving this thread and I do not mean to hijack it 😳 , but I was wondering if you think PMC DB1 could be driven by something as modest as Onkyo TX-8050?
Thanks very much in advance.
emberins said:Thank you for your quick comment, davedotco. I have since got a pair of KEF R100, actually. And although I understand the onkyo might not be able to realise the full potential of the KEFs either I can say the combination seems to sound very nice together.
