It’s good to see a lot more scepticism (realism?) regarding cables. I can remember a time when some were offering advice to others on how to fine tune their systems using cables.
			People still offer such advice, often based on the type of conductor used.I can remember a time when some were offering advice to others on how to fine tune their systems using cables.
No one is saying that, however believing you hear a difference (Biological life forms senses are easily fooled) and presenting this as fact without providing verifiable evidence is.As someone who's spent decades in this hobby, I've heard Ethan's arguments many times. While I respect his technical knowledge, he misses something fundamental - this hobby isn't just about measurements. I've personally experienced sonic improvements with premium cables that transformed my system in ways oscilloscopes can't capture.
Sure, not every expensive speaker cable is worth it, but dismissing all high-end speaker cables as "snake oil" is just as close-minded as believing they all make night-and-day differences. Our hearing is incredibly nuanced, and what matters is what YOU experience in YOUR system.
I'd suggest trying before buying and trusting your ears. If you don't hear a difference, save your money! But for those of us who do perceive improvements, it's not "fraud" - it's pursuing the emotional connection to music that drew us to this hobby in the first place.
Absolutely.As someone who's spent decades in this hobby, I've heard Ethan's arguments many times. While I respect his technical knowledge, he misses something fundamental - this hobby isn't just about measurements. I've personally experienced sonic improvements with premium cables that transformed my system in ways oscilloscopes can't capture.
Which components will you be auditioning? I'm not sure there's any point.Specifications are measurements, which you always have to take into account when choosing products to audition, to make sure you have a balanced system.
Reviews and opinions are next to narrow things down further.
Will if fit in your room and does it look good (Vitaly important to get it past your other half), also good for the long term, as there is nothing worse than being subconsciously irritated by the looks causing upgradeitis to set in.
You will now be able to select a selection of components to audition at your dealer, so as to be able to make the final decision.
Ignore cables, as any dealer worth their salt will supply suitable one's for you.
If you do not do the above in that order, then the chances of you getting a system that you are happy with long term, is next to none.
You can always tell those that did not follow the advice above, as there constant ly looking at upgrades, rather than just sitting back and enjoying the music.
Bill
You could just try telling the dealer what you want...Also I wouldn't trust a dealer to supply my cables (they may have a deal with a cable supplier like Nordost or audioquest) - I'd just buy my own.
				🤣If this contribution has been helpful, please like and subscribe.
Copy and paste much?My influencing on audio connectors: Looks matter most, and economy is next.
For several to a bunch more years, I haven't had to go beyond Amazondotcom for KabeDirekt quite satisfactory relatively-low-cost options. My most recent requirement was for a single pretty 3-foot toslink connector.
I saw on Amazon 3M Ruipro fibre optic 2.1 HDMI cable on Amazon for £62.Not specifically HiFi cables, but I recently changed few HDMI cables as I upgraded to 4K. The current 10m HDMI cable doesn't pass signals reliably with the 4K projector. Because it's an install with cable hidden, I went for Ruipro fibre optic HDMI cable that's HDMI certified. I got it for £76 during Amazon Prime sale recently. For the rest, I bought HDMI certified cables costing no more than £8-10 each.
The cheaper one is not HDMI certified and is a frequently returned product as per Amazon.I saw on Amazon 3M Ruipro fibre optic 2.1 HDMI cable on Amazon for £62.
Sort of curious, the optic fibre version is it compatible with standard HDMI socket?
Ruipro hybrid cables (fiber-copper) are very good cables and come with a lifetime warranty.The cheaper one is not HDMI certified and is a frequently returned product as per Amazon.
Yes, it is compatible with standard HDMI socket. It's unidirectional.
There's one word there that, without doubt, is the most relevant in the whole cable debate - that word is 'perceive'.I'd suggest trying before buying and trusting your ears. If you don't hear a difference, save your money! But for those of us who do perceive improvements, it's not "fraud" - it's pursuing the emotional connection to music that drew us to this hobby in the first place.
Actually, it's a very good point, if you ignore your feelings after hearing a blind test prove that there is no difference (This being factual), you may still not be happy with your system as your psychy takes presidence over factual, whereas if you go with what your gut wants (Even if it is proved to be nonsense) you will have a much more happy experience.There's one word there that, without doubt, is the most relevant in the whole cable debate - that word is 'perceive'.
Perception works (for some) when they know what they're supposed to be perceiving - but it doesn't work in blind tests.
And if something can't pass a blind test, ask yourself, "what's the point of it?"
Yes, that’s why my system sounds much better to me when it has been carefully dusted. I think it’s better, but logically it’s no different! 😂Actually, it's a very good point, if you ignore your feelings after hearing a blind test prove that there is no difference (This being factual), you may still not be happy with your system as your psychy takes presidence over factual, whereas if you go with what your gut wants (Even if it is proved to be nonsense) you will have a much more happy experience.
The only time problems occur on forums etc. is when people post opinion as fact, which has to be corrected for any newbies that come across the thread.
Bill
