The DAC scam
What a Shocker, it has to be a SCAM, Heinz Beans fails the Telegraph Taster Test but Lidl beans are rated highly
BBC Good Food "experts" rate Heinz and Aldi as the best and Lidl a bit behind. Though Aldi being 99p cheaper than the Heinz at Sainsbury, I know which I'd choose.
(You do realise the Nisbet's is a catering tin of over 6 times of normal Heinz size?)
I finally watched this video and I agree with everything he says. All the silicon chippery and power regulation parts, in a nice case and with a display, should cost no more than a few hundred quid. The very expensive products use the same DACs as cheaper ones. Expensive 'DACs' are the sane as expensive cables, snake oil and a true waste of money.
Another great video:
View: https://www.youtube.com/watch?v=hOOHneFYGYA
If you could give us some detail of the different DACs you've personally tested over a reasonable period of time in your home environment, how you volume matched them and how you managed to play the exact same source to each of them, would love to her more about it.
I trust the professional and technical people in these videos to do that for me. I'd rather trust their views and opinions than many of the wackos on this forum.
So then why buy seperate DACs and not rely on ones in integrated amps?
Perhaps people like wasting their money?
The DAC in my Audiolab Omnia costs £15 if your a vendor buying in bulk and I can confirm it does the job and sounds great.
I can't be bothered to check, but there must be around 6 DACs in use these days, from 3 or 4 chip makers.
These DACs are all fully capable of resolving modern formats and all do exactly the same thing.
It is a fact that many people are snobs and fully believe spending thousands on kit containing tiny chips of silicon, or a few metres of industrial strength copper, is worthwhile.
It is a fact that many people are snobs and fully believe spending thousands on tiny chips of silicon, or a few metres of industrial strength copper, is worthwhile.
I think we are back to the same old argument in that DACs are not simply about the chip itself but the whole of the circuitry that is necessary to make that chip function and how well it does the job.
Reactions: Angle Poise-Lamp
This is true and it's not just the DAC doing the heavy lifting, but there's also a finite amount you can spend on resistors, caps, other circuitry, displays and casework.
Some of these products have ridiculous price tags and the parts used inside are fairly cheap.
Some manufacturers still choose their DAC chips based on how they sound, so there must still be some sort of difference between them for the manufacturer's to go to that trouble. If they were all the same, they'd just use the cheapest they can get their hands on.
I think many companies use the latest and 'best' items or bragging rights. If you look at the specs of these DACs, they are very similar and their function is same across each model. As I mentioned above, there are (sticking neck out) less than 10 DACs in use for 'DACs' today and they are all around £15 to £50 so not much in it and the cheaper ones like mine are just last gen with perhaps different tooling costs and older architecture, much like CPUs etc. AKM and ESS make many chips and most are suitable for HIFI and media products. Some have higher operating temperatures for use in vehicles etc.
Clickbait, stupid video.
While diminishing returns are surely a thing, there's so much more that goes into quality D->A or A->D conversion, and getting your source digital signal into your output speakers than just what DAC chip or DAC device you're using.
Disagree 100%
Is that the "proessional and technical people" who are basically just "influencers" trying to make a name for themselves and get internet hits to make money.
There are as many "proessional and technical people" doing videos comparing DAC's and saying ones is better than another as there are people saying there's no difference or are you just selective and only believe the ones that suit your narrative.
Personal comment deleted by moderation.
Reactions: TRIPLE A
That's not actually true. True professional and technical people do not tend to say one DAC sounds better than the other unless there's something in it for them. And the reason is that professional and technical people tend to understand measurements, the limits of human hearing, and psychological effects. It only tends to be people who ignore one or more of those things who think DACs sound different to one another (barring filter differences in some cases).
I note that you did not actually name any "professional and technical people".
Ah the tried and tested, they're just influencers, if their views are being challenged, but professionals who's opinions are worthy of spamming the forums with if they "confirm" their views, narrative that's now being pushed by the fully paid up subjectivist audiophiles on this forum with regularity now it seems....
Reactions: ToppingSMSL
The subjectivist view is just such a bad take in my view as it goes against all the established science and psychological studies.
So, per your logic, every feeding of a given track into a DAC chip is exactly the same stream of ones and zeroes, no matter the transport method?
Do continue, let me know your thoughts!
It will be the exact same stream of ones and zeros. There may be varying amounts of jitter affecting the timing of that data flow, but jitter is pretty much a solved problem these days and even cheap DACs are capable of performing well in jitter tests.
Reactions: TRIPLE A
You’re absolutely right about timing affecting the stream! My point is that it isn’t the exact stream of ones and zeroes when the timing is different from that the content creator intended. Semantics perhaps but I think worthwhile making the distinction
Like I said jitter is a solved problem. Jitter in modern DACs is below -120db for the entire frequency range.
Digital isn't the impervious signal that many seem to think it is - all "ones and zeros" doesn't always cut it, especially when it actually isn't ones and zeros. You can boil digital down to its basics if you like, and if that gives you the info you need to justify your views, fine. But that doesn't make it the truth.
