Question Technics SL1500c
dfe76
Hi all i'm looking at buying a Technics SL1500c turntable, & need help/advice with choosing an amplifier
& speakers to compliment it any help would be much appreciated
twinkletoes
654
454
2,270
Hi Budget around £1000 to £1200 room size approx 6m x 6m
Rotel tribute, marantz, nad, bluseound power node
Speakers
Kef, mission, wharfdale, q acoustics
Just to start you should find somthing within the ranges to suite your budget
Or you could go the active speaker route and go with some klipsch 5/7/9s for example depending on space.
Unlike many other sources, turntables and their attached cartridges are less proned to poor synergy.
I would advise you to book a demo with a retailer such as Richer Sounds and listen to few different options. But demo amps with built-in phono stages as you can test that against the built-in stage on the turntable.
Reactions: dfe76
SteveR750
Slightly left field option that's excellent value:
Amp - Yamaha A-S501
Speakers - Elac DBR62
The Elacs punch way above their price point, but need a decent amp as they're a bit more difficult to drive than most budget speakers, but the Yamaha is well up to the job.
The yamaha is around £400 and the elacs £480 if you shop around online.
Reactions: dfe76
