need a bit of help;
i had a dodgy figure of 8 mains cable plugged into my sky box which was running off the tacima. the sky box was not working so i fiddled with the power cable and my house electricity tripped and smoke appeared briefly from the back of the sky box. the tacima will now not power any equipment and i can only assume i have blown the fuse inside. my questions are thus:
1) do you think I have done major damage to the tacima and should i get a new one?
2) if it's ok, does anyone know what screwdriver i need to open it up and change the fuse (if poss).
thanks in advance.
thanks in advance.
