CnoEvil said:acalex said:Indeed...and in my opinion sounds great!!! Maybe 2x50W (at 8 ohm) is not enough? I might want to upgrade in the future for this reason? What do you think?
The Denon I tried also was I think 2x90W or something like that...
Don't get caught up in the "power rating" of amps, as specs alone can be misleading. If you are getting a sound that you love, at your regular listening volume.....sit back and enjoy and ignore the "itch" to change. If you like Vincent amps, when you eventually do change, it may well be one of these very excellent amps, that you should consider. They do tubes and hybrid (I think) as well.
Yes you are right...I really love the sound of this amp indeed! Really would like to try it at higher volume but I can't...do you know this German brand of amps? It sounded "stronger" than the Denon I tried (which unfortunately do not remember the model but was priced at 899 euro whilst mine at 699...but I bough at 499 cz was the demo!)...and I listened it carefully sitting on that armchair for a while and switching amongst the 2 amps (speaker I decided straight away!!!)
