Where to begin?
GolfGirl
Hi to all, new member here. About a year ago I bought an Audio Technica turntable, model is AT LP120 XBT-USB. I've recently moved house, and am intending to set the turntable up in the lounge with some nice speakers and also to add in something that I can play my CDs on. My main aim is to build a system with decent sound so I'm probably not looking for bargain basement components, but at the same time I don't want to be spending thousands! I've been looking around for a while now, but to be honest I'm not sure where to start and am scared of making an expensive mistake. Could anyone advise please?
PS I have loads of vinyl going back to the 1970s and also loads of CDs.
Welcome to the forum. Yes, the world of hifi can seem vast and confusing at first, but a few simple questions can help some recommendations.
You have a turntable, so you’ll need amplifier, some speakers and - it seems - a cd player. These can come as individual separate boxes or all-in-one units. Separates will give arguably better sound and the opportunity to swap and upgrade later, but you’ll have a stack of boxes.
First question is how big is the room in which this will be used? This will help recommend some speakers and matching equipment.
In the meantime, have a look at somewhere like Richer Sounds to see what’s available at different price points. They do some good deals on bundles:
Then you’ll need to consider how much you wish to spend? If you’re prepared to consider used equipment, you’ll get better value and more for your money, but some like the security of buying new.
Hopefully, this will help make a start.
Hi, wellcome to the forum. Pls. let us know how big is your lounge, if you have a space for floorstanding speakers. Which music do you like? This will help us with better advice for you. Do you have some price limit for new equipment? Kind regards.
The lounge is 15ft 9in x 15ft 9in. Not keen on buying second hand, would rather have new. Probably would not want to spend any more than say £1500 - £2000?
Lounge is 15ft 9in x 15ft 9in. Yes floorstanding speakers would be an option. I play rock and pop, prog, that kind of thing. Would not want to spend more than £1500 to £2000, if that is realistic to get something that sounds good?
why have began with just a turntable if your not sure where to start ?
A room that size definitely lends itself to floor standers. Where it gets tricky is that speakers are a very personal decision and the way they will interact with your room and its surroundings will shape the sound you hear.
The best thing you can do is try and get to your local dealer and try to listen to a few different setups. Don’t give them your budget to begin with as they’ll just try and squeeze more from you. Ask to listen to a variety of systems at different price points.
Reactions: GolfGirl
There is no substitute for going to listen to a system, or even better borrowing equipment to listen at home. For your budget, I would consider the following:
  • Marantz PM6007 £369 (you will need to spend £600+ to get better
  • Marantz CD6007 £349 (CD players are making a comeback, but never went away for Marantz, they have been amongst the best budget players since the 80's)
  • Q Acoustics 3050i £449 (as with the amp, you will need to spend a lot more to get better, and they look good too)
  • If you want to add a streamer Wii Mini £89 or WiiM Pro £149
At just over/under £1,300 depending on the streamer option, or £1,167 without a streamer, you are well within budget. The Q Acoustic are heavily discounted at the moment, so probably not much more to be done with that price, but in general if you buy speakers and amp together there is usually some discount to be had.
Reactions: GolfGirl and DougK1
are we assuming you need;
1. An Amplifier with Phono input for your AT TT.
2. A CD Player
3. Speaker + possible stands ?
As mentioned above, if you are in the UK, the Richer Sounds is an ideal place to start. Cambridge Audio equipment is fantastic value for money and they have an online community where their employees support the community. Richer Sounds are the primary UK dealer for Cambridge products.
I bought the turntable so I could start listening to my old vinyl again. I used to use it with my Bose Soundlink Bluetooth speaker. Circumstances have now changed, I've moved to a new house and I fancy setting it up with better sound, and also getting a decent CD player so that I can listen to my CDs again. You could say that the turntable was a 'forethought' or that building a system round it is an afterthought!
A square room isn’t ideal for sound, but as long as you have room to experiment with speaker placement you should find a compromise.
Smaller floorstanding speakers take up the same space as a stand mount on a stand. Do you want to include ‘streaming’ as well as playing your collection of LPs and CDs?
As a ‘starting point’ to spend your entire budget - they’d include cables I’m sure - something like this covers a lot of bases, is versatile, and you will be able to see and hear if you’re in the UK.
But do look for an independent local dealer if you can. 🙂
Reactions: Shrek and GolfGirl
Peter Tyson also has some very good bundle deals to explore.
You do really need to get to a dealer and have a listen to some options. Buying new hifi blind is a costly gamble.
Whereabouts in the country are you? Somebody might be able to recommend a dealer.
I'm in South East Scotland. Would probably need to get someone to take me up to Edinburgh to find a dealer, which is a bit of a trauchle. I was hoping to avoid that really.
Reactions: Shrek
i did wonder what you used has a source i have the same TT i upgraded the stylus to a Shibata good improvement food for thought for the future .Good luck .
Reactions: GolfGirl
If you’re anywhere near Anstruther, Fife, then there’s a great dealer there called Elite Audio. They do tend to be luxury priced but they have a great selection of used gear, so might be worth considering.
Or down to Carlisle to see Peter Tyson?
Reactions: GolfGirl
Picking up on a suggestion here, Peter Tyson do a bundle on the Marantz PM7000N and the Q Acoustics 5040.
Q Acoustic speakers are excellent value, sound great and are easy to place and drive (not all speakers are).
The Marantz is a streaming amplifier with a phono input so you can connect your turntable and cd player, as well as stream - great for discovering new music.
You’ll even have money left over for the excellent matching Marantz CD6007: it’s all the cd player you’ll need.
You’d have an excellent, modern set up.
Just a thought.
Welcome to the forum!
I see you're over in the Borders - I used to stay over that way a few years ago for a while. Bit short on hifi dealers admittedly...!
If it was me (which is my way of saying you can regard or disregard this as you see fit), I'd get a list together in my head of the kind of sound that I like - bassy, clear, detailed, balanced - the kind of music you're into and how you might go about putting a system together. Needn't be a chore and in truth, it's probably something you're already aware of at least in part.
Seeing as you've got your turntable and a rough budget in mind, you've got a couple of routes you can take next system-wise; a traditional amp - speakers setup, or going down the active speakers route.
I can see a few replies recommending you hop in the car and head off up to Edinburgh (which I think you've said you're not fussy for), Anstruther (further away and more hassle to get to), or *** down the A7 to Tyson's. Google Maps is your friend guys...or any map frankly.
Plus you've going to have to faff around with Edinburgh's Emission Zone if you go near the city centre (Hi Fi Corner is outwith that), so you'll need a Euro 6 vehicle plus the best part of £15 - £20 for parking if you're looking at two hours in the city centre.
So, all that's all well and good, but do bear in mind that not all dealers carry all the gear you're maybe interested in instore. My own experience recently with Hi Fi Corner up in Joppa in Edinburgh was very poor - a very well stocked shop, leaning mainly towards the high end, but you really need to phone ahead to book a demo ("we've got more on the website mate" was the unhelpful reply from the guy instore when I was in a month or so back enquiring about a phono stage) so they can get the gear you might want to hear in.
The same is true of Peter Tyson in Carlisle and while they've a heap of floorspace in their large store, most of it is for domestic electrical white goods and TVs than hifi. Much more helpful team, but you really need to have an idea what you want before you go in as you'll spend an hour or two getting there and it'll be "we can get it from the warehouse in Newcastle").
The other thing to bear in mind with buying in a dealership is that if you change your mind when you get home because the speakers or amp don't sound so good in your living room as they did in the demo room, you're at the mercy of the dealer if they'll take it back and swap it for something else. Some will, some won't (the latter being James Morrow in Edinburgh). Reason being - in law - you've had the chance to inspect or hear the goods.
Buying online is a different matter and you're entitled to take the goods out from their packaging and in the case of hifi that's pretty handy. Any dealer saying that you can't is flouting the law so I'd avoid those. Plenty offer a 14 day return, others more (Cambridge offer 30 day returns on their direct purchases).
So, you've got £2,000 to play with. Again, if it was me, I'd do a little legwork online to see what's available. That's a pretty good budget so you don't need to stay stuck with entry level gear. Get a shortlist together on paper or a spreadsheet that chimes with your mental note previously on the sound you like and trawl the reviews - both from pro reviewers and user opinions too. It might be a little time consuming but it needn't be onerous.
I haven't bought gear from a dealer since about 2011 when I bought some Tannoy DC4s. Since then, I've bought a ton of stuff online but my core system is a pair of AVI active speakers, a Cambridge Alva ST turntable and AT-540ML cartridge, a Cambridge 200M DAC and a revolving series of CD players or universal players, which currently are the Denon DVD-3930 and a Pioneer PD-505SP. I'm not sure I'd be splashing heaps on a new CD player myself, these days I tend to buy older serviced models from the 90s and early 2000s. My most recent model is a Cambridge 752BD blu-ray player which dates from 2014.
I've avoided specific models here - there's a ton of it out there. You can't hear it all, you can't hear all the combinations and you haven't got the time. Nobody can and nobody does, so you might as well make it an easier route for yourself.
Eversolo Play Streaming Amplifier, CD edition at £699. It has a built in phono stage as well. Future proof if you ever get into streaming. Just add speakers. Dali Oberon 5 in dark walnut for me, but there are a load of choices.
