- Aug 10, 2019
- 2,556
- 4
- 0
Hi....
I really want to get surround sound and want to be able to use the same system to play music on but I'm not exactly sure what I need (amp and/or receiver) and how it will fit in with what I've got at the moment.
I do not have a DVD or CD player and do not want either. All the movies and music I listen to are on a networked hard drive which is plugged into my router. I then have a netgear EVA8000 HD media streamer plugged into the router and also into my 50" HD TV by HDMI cable. I'm really pleased with the output but would like to get surround sound instead of just using the TV speakers. I also currently listen to music this way through the TV or through my PC so would like a better way of doing this.
I don't really want to get one system for the music and one for the TV and I'd also prefer wireless rear speakers. My room is fairly big (about 7 metres by 5 metres although the TV is towards the corner). Would I just need to buy a receiver that I could plug the netgear straight into and then plug the receiver into the TV and into some speakers? Would that work?
As for music, will I need some sort of interface to listen to it if the TV is off, given the music is on a hard drive? Will it all have to still go through the netgear?
I'd rather not spend too much more than £1000 but will if thats what it takes. Can anyone point me in the right direction or recommend anything?
Many thanks.
Many thanks.
