The use of a subwoofer is of paramount importance. For eg. pic. below shows KEF Reference 3's which are perfectly capable of good quality low frequencies. However this system features a pair of JL Audio Fathom f112 v2 subwoofers and a JL Audio CR-1 active subwoofer crossover with a crossover point to the main speakers set at 90Hz, so the Reference 3's speakers are relieved of the need to produce deep bass. This crossover point relieves the main speakers of the bottom two octaves (20Hz - 40Hz and 40Hz - 80Hz) and more which lowers distortion in the main speakers. The Fathom f112 v2’s do a much better job in this region. As a result the system is more transparent and dynamic from bottom to top, at low volumes as well as at higher volumes and the space in the original recording is much better defined than the KEF Reference 3's on their own.If your speakers are so unsatisfactory that you feel the need to add a subwoofer then you have bought the wrong speakers in the first instance.
And now it starts to get expensive.
Getting the subwoofer in perfect sync with the front speakers requires a bit of work.The use of a subwoofer is of paramount importance. For eg. pic. below shows KEF Reference 3's which are perfectly capable of good quality low frequencies. However this system features a pair of JL Audio Fathom f112 v2 subwoofers and a JL Audio CR-1 active subwoofer crossover with a crossover point to the main speakers set at 90Hz, so the Reference 3's speakers are relieved of the need to produce deep bass. This crossover point relieves the main speakers of the bottom two octaves (20Hz - 40Hz and 40Hz - 80Hz) and more which lowers distortion in the main speakers. The Fathom f112 v2’s do a much better job in this region. As a result the system is more transparent and dynamic from bottom to top, at low volumes as well as at higher volumes and the space in the original recording is much better defined than the KEF Reference 3's on their own.
With all things being equal a subwoofer is the most important component. Ideally frequencies up to 90Hz should be unburdened from the mains and this LF burden passed on to a subwoofer to deal with.
I believe to achieve 'realism' requires power and even if the mains go down to 20Hz a subwoofer should still be incorporated because in my experience a subwoofer can inject power into and energise a system like no other component can.
The goal is to effectively align, calibrate, dial in a subwoofer so that the subwoofer integrates seamlessly with the mains and disappears into the soundstage with a deep, sharp, tight fisted, fast and powerful punchy sub bass.
I'm not sure I understand your point.like I said music is meant too be fun not this. Far too much DRAMA.,
100% the roar of the fifth symphony will shine through the subwoofers. 🔆😊Ah ha, now I understand, thanks Jason, for enlightening me. I tend to forget that sound systems are used for gaming, not being a 'gamer' myself.
I wonder if a subwoofer would add to the dramatic effects in Beethoven's Fifth Symphony.
Even with classical music, a sub will add a lot of nuance and background fill. The sound will be "fuller"....don't really think a sub woofer would be a necessity for me? I think.
My stand mount Theophany speakers will go down to 45 Hz which is similar to the Kef's but still the sub makes a huge difference - even though the sub only goes down to 27 Hz.
Also, keep in mind that two mediocre subs don't make a single good sub...
Thanks for your thoughts. I think on balance with all the thoughts on subs from those with the actual experience of using them and hearing the difference they make to the overall sound a subwoofer has to be on my list of additions to my set up. 👍🏻
Thanks again Jason, you've been most helpful and I value your advice.It's also worth exploring floor standers as an option. You can sell the KEF's for a very good price. If you like the KEF's signature and tonality, the Focals are very similar 🙂
Shifting the low frequency to the subwoofer allows the speakers to breathe and if done correctly the subwoofer will disappear.
From my personal experience, the musical envelope was enlarged with the addition of the subwoofer.
Thank you very much for your advice. I'm very new to all this. A hi-fi to me was always source, amp, speakers, being the oldy that I am. I certainly don't necessarily even want a sub. For some reason in my mind I didn't like the idea of floor standing speakers, I prefer the look of smaller speakers on a stand. But, really perhaps floor standers are better if one wants the speakers to produce the lower frequencies that many 'bookshelf' speakers can't manage.Just bear in mind that subs need careful room placement and room correction in order to get the best out of them, and certainly to get the best out of them in any given room. Most hi-fi amplifiers won’t provide bass management or EQ, and badly set up subs will be a negative addition, regardless of the cost.
For the benefit some subs can bring, I personally don’t see the point in adding subs that cost virtually as much as the speakers themselves. Don’t overlook the fundamentals - get the speakers right first.
if it is too small floor standers would have made things worse with uneven bass.I have a question. I wonder if anyone would mind offering some advice please. I'm playing CDs through a CD player into a Marantz PM8005 and KEF LS50 Meta speakers. Is it possible and is it worth it, if it is possible to add one or two subwoofers to this system to extend the low end response. I believe the speakers are not capable of reproducing low end frequencies below a certain level. I can't remember what the low end limit is but is it worthwhile if possible, and I don't know if it is feasible to add to the system to go lower? Any advice would be most appreciated. Showbox jiofi.local.html tplinklogin
These are small bookshelf speakers, not enough for full-range audio. Subwoofer requiredKEF LS50 Meta
Today I sold the KEF LS 50 Meta speakers. What a relief.These are small bookshelf speakers, not enough for full-range audio. Subwoofer required
What acoustics did you choose?Today I sold the KEF LS 50 Meta speakers. What a relief.
Now I'm beginning to understand what speakers I want.
I bought a set of B&W 805 Matrix stand mount speakers. Excellent speakers in my view but not quite enough bass for my liking.What acoustics did you choose?
There is an old school of thought who hold the view that if there's a need for a subwoofer then you have the wrong speakers.I bought a set of B&W 805 Matrix stand mount speakers. Excellent speakers in my view but not quite enough bass for my liking.
Today I took delivery of a B&W PV1 Subwoofer. It took me 20 minutes or so after messing with phase, frequency cut in, and sub volume.
I'm amazed. The sound now is excellent. The punch it's added to the drums and bass is incredible. No regrets whatsoever.
I wouldn't necessarily say that if you need a sub, you have the wrong speakers. Not at all. Whith the Marantz Model 30 that goes down to 10 Herz this set up is now exactly what I hoped it would be.
I didn't have the trouble setting up the subwoofer that people speak of.
Maybe I was lucky, but it all works brilliantly.
With your fondness for classical I thought it would only be a matter of time before you explored the sub route. Standmounts are great but they do lack the scale needed for classical, my opinion of course.I bought a set of B&W 805 Matrix stand mount speakers. Excellent speakers in my view but not quite enough bass for my liking.
the characteristics of this acoustics are similar to marketing/hoax 🙂set of B&W 805 Matrix
If you decided to take a spherical subwoofer, then why didn’t you buy acoustics of the same shape? The design should be uniform 🙂B&W PV1 Subwoofer.
