Subwoofer cable adaptor.
Nimeacuerdo
Hello, guys! How is it going?
I was wondering if anyone knew where to get an adaptor to join both ends from a speaker cable into one so that you connect it to a home cinema player, as shown on this picture (the subwoofer one): http://www.planetbrands.co.uk/images/2 LG BH4030S - HOME THEATER SYSTEM BLU-RAY 3D 250x233.jpg
It is difficult to explain...
I have just got a LG Home Cinema System BH4030S and the subwoofer is connected to the player in a different way as the rest of the speakers.
I would like to get one of those orange adaptors, if possible.
Thanks a lot for your help, I really appreciate it!! Have a good day.
Regards.
simonlewis
590
A subwoofer uses rca/phono connectors if your home cinema player doesn't have the right connection i can't see it having a subwoofer connection/terminal, afaik subwoofers are mains powered which is why they use rca/phono.
MajorFubar
690
7
His LG uses a 2-pin connector for the sub that's fairly common to all-in-one home cinema systems. On ebay you can buy cables terminated in the plug at one end and bare wires at the other
EDIT: this looks to be it. http://www.ebay.co.uk/itm/SONY-SINGLE-SPEAKER-CABLE-LEAD-WIRE-CONNECTOR-PLUG-ADAPTOR-HOME-CINEMA-THEATRE-/161185848531?pt=LH_DefaultDomain_3&var=&hash=item25876cdcd3
(Feel free to shop around; this seller's prices don't exactly blow me away.)
