omnibeard
ESP2009 said:Comparing the sound quality: well, the SBT does a very good job. It is connected via RCA cables into the Uniti for DAC and amplification purposes. The performance is more than satisfactory, especially given the ease of use. It's just that when I switch to the Uniti there is a step up in terms of punch, focus, presence and atmosphere/mood. In addition to avoiding a tendency towards loose, slightly splashy top end sounds, the Uniti gives an added breadth and depth, together with an extra warmth - it's more natural sounding and displays greater control over those sibilant pitfalls that cause the SBT to stumble a little.
But if you factor in the cost of the Uniti at over £2k (until the Uniti 2 really takes hold) vs the SBT at under £200 plus a decent amp (and DAC?)...yes, I must be mad! :bounce:
I reckon I can live with both, depending on who is present and any further refinements and fine-tunings I can get done. But, believe me, the SBT hype is not necessarily that - it's a bloomin' steal at under £200 so well done Logitech. :cheers:
Interesting. If you find that sort of thing interesting. So, just to check - you connected the SBT via RCA cables, ie. using the SBT DAC?
