Speakers for Linn?
Besty
9
Hi folks,
Vintage, but I'm really hoping someone has owned these and can offer insightful advice! I have Linn Classik, LK85, Arcam rBlink, Arcam MCD all mint condition. Linn K20 wiring etc so not bad. Currently wired to B&W601 s2 again mint condition. Want to upgrade speakers but on a budget and have two choices as a preference.1) pick up some mint condition Linn Katan's c£4002) pick up some mint condition PMC Db1 c£450. I'm sure there are a million other options but I don't want to spend over £500 really and think that both options should be better than my B&W's (?). I'm really hoping someone on here has experience of these and can offer your thoughts. Thanks in advance.
I used to haves Linn Kairn/LK100, with the original Naim NAC cables (same as Linn's K20, I believe).
I used them with MA R852, which are probably too old to consider 2nd hand.
Depending how smooth you like the sound, you might consider second hand Spendor, Sonus Faber or Harbeth. I think the PMCs would work nicely, as would Linn.
