Hi - some suggestions please for speakers to use in an Arcam FMJ 37 based system. They must be quite close to a wall in a room 21 ft ling by 11ft wide.
I could use PMC DB1i's.
Al ears said:
21 ft ling....... that's a big fish *biggrin*
Seriously agree with cnoevil in that you might need a decent subwoofer to supplement bass output.
When you say you could use DB1i's do you mean you already own them?
If you are looking to buy others what is your budget?
21 is not that long my room is 28 long, speakers and bass not lost but I have them firing across the room not down.
As far as UK modern housing goes 21ft is long. However, it's the 11ft wide that worries my, that is an aukward shape.
OP did not post orientation of speakers so let's hope he comes back with more info.
but 11 is quite normal, having just moved many rooms were that width, having gone from 16 x 11 to 28 x 11 I have not noticed that much difference, I thought the bass would have less but that's has not been the case.
Interesting that bigH all the rooms in my house are 'squarer' like 16x13, 18x14 but whatever.
If you say bass is fine I bow to your greater knowledge. OP did not say which way around he intended to use speakers just 'close to rear wall', and I wonder if he already owns them or not as, if he did, surely the easiest thing to do would be for him to have a listen utilising both layouts if possible.
