- May 25, 2009
- 41
- 0
- 0
At the moment I have my 685s on pretty old, pretty cheap speaker stands which I plan to upgrade at some pount (any recomendations?)
My question is this..currently the stands have spikes that travel though the carper/underlay and sit on the concrete base below. I have some little pucks/disks that came with the stands so that the spikes could sit in them, I currently do not use these. in my situation is it recomended to use them, is spikes on concrete a good idea?
Also... another question.. With my speakers came some foam bungs (i dunno what they are called) I know that by fitting them to my speaker it adjusts the sound, but can anyone give me a technical reason why this is, and what to expect if I ever do fit them.
I know in both of th above I could simply try it and see, but Im not to sure what im listening for, and you guys are way more knowledgeable than me 😉
