Speaker cables - length & suitability
Yeshawk
Hi, I've just upgraded my amp from an old Nad 3020A to Roksan Caspian M2, with a matching CD player. I have a pair of oldish B&W 703s and Linn K20 cables. Would I benefit from upgrading the cables to something like Chord Odyssey or Naim NACA5, or something similar? K20 cable still seems to be well regarded by a lot of people.
Another issue is my equipment is to one side of both speakers, so my cable lengths are 5.5m and 1.5m. Is it really necessary to have a matching pair as some dealers would have you believe? Going up a notch to something £20-30/m is fine but allowing for excess length which may not be needed rankles a bit!
seemorebtts
66
I would keep what you have.if you want to make an upgrade go for a power cable like clearer audio chopper line at £175.you get a 30 day money back guarantee.your speaker wire is very balanced so start with a good power lead first and try the chord shawline interconnect at £180.i have one speaker wire length at 1.5 meters and one at 3 meters I can't tell any difference.
Yeshawk
Thanks for responding seemorebtts, I had a feeling that might be the case! I've already got some Chord and QED interconnects so maybe I will look at the mains cables.
seemorebtts
66
what chord and qed do you have as some are not good
Yeshawk
Chord C-line for bluetooth receiver and headphone amp, Linn for phone stage, QED Performance for bluray and Chord chameleon for the CD
seemorebtts
66
these cables are fine.you should look into the power cables as I think it's the best upgrade.good luck
