speaker cable
Can anyone recomend a good budget speaker cable.I am on a very tight budget as i have to get 33 meters of cable,would QED micro or QED flat cable be good enough for my system,very little choice where i live so will have to buy online.Thanks.
Sony BDS360 blu-ray player/Onkyo 606 Amp/KEF 100.5 Speaker system
i dont see why it wont be good enough for your system, plus if your on a budget your options do beome limited but this cable should be perfectly fine for your system plus the QED micro are nice and easy to hide away
QED micro is a good quality budget cable but the flat QED stuff is utter garbage quality wise IMHO. I would go with Ixos 233 flat or the fisual stuff. Van Damme Blue 1.5mm and Hifi 1.5mm cable is also recommended.
