Speaker cable upgrade help needed
bullitt
80
16
I just bought some QED silver anniversary xt for front and centre speakers, i also want to upgrade my surround speaker cable aswell i currently have 79 strand cable but unsure which cable to buy, ive been told QED micro qm200 is a good choice, would like some advice please.
Van Damme Blue or Van Damme Hifi would be a good upgrade. Both are excellent cables and value. If they're good enough for PMC and the studios...... vdctrading should be able to sort you out.
I decided on QED MICRO for the rear, i needed to make a decision quickish im decorating this week and changing my setup,thanks for your help.
Just on the subject of cable i found a product in b & q the other day called D-LINE cable (£13 a pack of 4 x 3mtre) management, looks like the exact thing ive been looking for, anyone else used this ? do you know anywhere that sells it a bit cheaper ?
Screwfix and tlc sell it, screwfix is same price, tlc sell it all seperatly so not sure, thanks for your help, i will post up when ive done my room.
Well i just spent a whole week as well as money lol on my room decorating changing things around, i used D-LINE cable management for all speaker cables,very impressed,very neat and tidy.
a no brainer.
