Speaker cable for Kef XQ30
Jon Smith
Recently upgraded to some Kef XQ30s and want to upgrade my speaker cable to match.
The Kefs have a reputation for being bright, they sound OK to my ears but I don't want to make them any brighter. What sort of cable should I be looking at?
From googling around the Chord Odyssey and the NVA LS3 are highly recommended, but would they be a good match? Does anyone have experience of these speakers and which cables would you recommend,
[i'm currently using Van Damme 2.5mm so will compare the newer cables to these and see if it's worth the upgrade]
totally agree here. seeing as though biwiring costs double the amount , u can get a much higher quality cable singled wired for the same/little bit more £
