Hi
I'm looking for a recommendation for a fairly mid range/decent sound system set up for a cienma room? I've not done a full on proper ceonversion - it's a high ceiling Victorian room, solid walls, 3x3m with no sound proofing and has wooden floors so sound is hardly going to be the best it can for all you. I just need a good value AV with speaker package but where to start???
Also, any advice on shelving the various units? The projector wil be on wall bracket, but I have to make a shelf for the AV, a set top box, Blu Ray player and PS4 - a lot of weight and when I was just browsing looking at AV's I was looking into the Denon AVR X520 and it's huge! Most appear to be over 300m deep, without allowing for space for the cables at the rear, that's crazy, most shelves don't come deeper than 300mm/12". Ideally wanted a floating shelf but can't imaging I'll find anything to hold the weight with the required depth.
Thanks for any help
Thanks for any help
