First off, sorry for the barrage of info and questions. My understanding from some brief reading is as follows:
Sound Bars do not play true 5.1 audio.
Using HDMI Arc will not send HD audio to my soundbar from my TV. (true or false)
To get HD audio from my PS4, Bluray & Sky I would need to use HDMI cables direct to the Sound bar using Arc to forward on the picture to the TV (true or false)
Now, if my sound bar isnt playing true 5.1 audio, then surely it doesnt matter whether I attach the sky box, PS4 etc to the Tv and use the Optical cable to send all the audio from the TV to the sound bar, one cable neat n tidy?
Am i confusing 5.1 with HD audio?
Would my set up sound better with everything coming from my TV to the soundbar, or everything going to the sound bar then on to the TV?
My problem is that the 4 Sound bars I am torn between, some have no HDMI inputs but are very highly rated, but the cheaper ones have HDMI Arc inputs and outputs.
Canton DM50 or Philips HTL5120 or Yamaha YSP-1400 or LG NB4530A or Q Acoustics Media 4 (my tv: LG 42LA640)
Thank you in advance for any help?!?!
