Sony STRDA2400ES or Onkyo 607
Garth Man
156
I have looked at the Onkyo 607, which i though was ratehr tasty
Richersounds are selling both of these now
Sony £399
Onkyo£ 449
Which is best overall from these two. Does the Sony pinch it in terms of Dynamics, Clarity etc
Is dialogue clearer, is the sound as beefy?? I would ask for a test, just Richersounds are poor for that!!
(driving the girlfriend crazy debating that i need a new amp!!!)
G Man
Hi G man,
I assume you will be using this system for stereo playback too?
The Sony is seen as the better amp, overall, but it has been said that the onkyo amps work well with the KEF eggs.
If you are using this system for home cinema only, the Onkyo 606 might be something to look at, if you can find one. From what i can tell, the 606 is seen an slightly clearer for vocals than the 607? (Might be incorrect statement-please check)
Hope that helps....
Had the 607 about a month now and can tell you it gives film soundtracks a lot of grunt which I like. Cloverfield, Batman, Bond etc sound excellent. No problems with vocals, though I did increase the volume on the centre slightly and its not used for music so really can't comment on that. I would recommend but as always best to demo.
Hello, I am in simmilar situation and would like to see which one is better. I have bought and delivered Onkyo 875 (refurb ..£499) at great price but unfortunately, its too big to fit in my TV cabnet, so have to replace it with smaller one.
