- Aug 10, 2019
- 2,556
- 4
- 0
Hi Folks,
Was initially looking to track down a Sony 2400es to pair with some Kef 3005se and QED Silver Anniversary XT cable. Hi Spek say they have stock of the Sony but I can't easily get to St Albans to demo... Richer Sounds don't have the Sony receiver but have suggested instead that they can do an Onkyo 577, Kef3005se and Ixos XHS553 for about £50 less.
Which do folks think would be the better choice for both amp and cable? Ideally want to get reasonable music performance from amp as well as movies? Should I consider the Onkyo 607 as well?
I have tried finding reviews of the Ixos cable (have already seen that the QED XT seems well recommended) but without much luck, so any steer on these or alternative cable choices would be much appreciated!
Cheers,
Cheers,
