Sony DAV-IS10 - Cable lengths and wall brackets
Hi, I'm think about buying the DAV-IS10 as it fits my bill but does anyone know how much cable you get for the rear satellites and if it comes with brackets that you can fix these to walls.
Thanks,
I'm not sure of the exact length but the speaker setup allows for up to 7m distance between the listening position and the front and rear speakers, so on that basis the cable is approximately 14m long. The speakers also come with neat little wall brackets.
Steve
