Sony DA2400ES 3d capable??
AndrewFG
44
I just purchased a Sony 46HX850 TV and am investigating what other equipment has to be replaced to enable playing 3d blu-ray discs. I know I have to replace my Blu-Ray Player (subject of another post elsewhere), but I also have a Sony DA2400ES receiver that I am very happy with.
Currently I have the existing (2d blu-ray player) feeding HDMI to an input on the DA2400ES, and the 46HX850 connected to the main HDMI output of DA2400ES (as you would expect).
So I have three questions:
1) Does the DA2400ES support a 3d HDMI feed through; i.e. wired exactly as my current 2d setup?
2) Is there an alternative way of wiring the Tv, the Blu-Ray player, and the DA2400ES so that the former two are connected directly for the video, and the latter two for the audio?
3) If "no" to both of the above, then what do you reccommend as a receiver that equals or exceeds the DA2400ES?
robjcooper
61
Hi Andrew,
I too have the 2400 and am very pleased with it. In answer to 2 of your questions:
1: Unfortunately it doesn't support 3D so you wont be able to just plug a 3D blu-ray into it where your current one is.
2: What I do when I want to watch some 3D is as follows. Direct HDMI connection from Sony Blu Ray to Samsung TV. I already have an optical cable which sends the audio from the TV back to the 2400, so I just select the optical TV input on the amp. The disadvantage is that you cannot get either Dolby True HD or DTS-HD Master audio as optical digital doesn't support it.
Hope that's of some help
Rob
B
BIGBERNARDBRESSLAW
Alternatively, if you buy a blu ray player with twin hdmi outputs, you can send one to the amp, and one direct to the tv, and will get a 3D picture with HD sound. This will save a lot of money, and the end result will be the same.
Among the Blu Ray players that have twin hdmi outputs are the Sony BDP-S790, and the Pioneer BDP-450.
B
BIGBERNARDBRESSLAW
Too slow, BB beat me to it.
AndrewFG
44
Thanks for the helpful reply.
I checked the 46HX850 Tv's setup options for the digital optical audio output, and it offers two settings namely "Auto" and "PCM for receivers that don't support Dolby". So this seems to imply that on Auto, if fed a Dolby surround signal via its HDMI inputs, it would then pass the same signal out via its digital optical output. So the question is now whether the DA2400ES could handle such an "Auto" signal coming in over the digital optical input?
AndrewFG
44
bigboss said:
Bear in mind you cannot get HD sound formats that way.
If what you say is true, then I don't understand why the TV would be offerring the two options "PCM" vs. "Auto" -- since (obviously) the PCM must be the old regular 2-channel audio, and therefore I assume that the "Auto" must be something more; i.e. with multi channels etc. Or ??
Andrew Everard
1,878
Multichannel yes; HD multichannel (ie Dolby HD/DTS-HD) no. If you connect a BD player direct to the TV, it will 'downshift' the audio to the format the TV can accept.
B
BIGBERNARDBRESSLAW
As you're going to buy a 3D blu ray player anyway, if you buy one of the ones suggested by myself and BB, you'll have the result you want, 3D picture, and full HD sound, and all for around £200.
If you buy a new amp and blu ray player, it'll cost you lots more, but the result will be the same.
It's up to you, but I'm about to be in the same position as you, and I'll be buying a twin hdmi blu ray player.
strapped for cash
417
So you'll be offloading the free Panasonic BDP?
I'll be experimenting. If PCM via optical sounds reasonable (it certainly won't sound bad), I'll keep the Panasonic for 3D and use my Denon BDP for all other Blu-ray duties.
The budget Panasonic is reportedly an excellent 3D Blu-ray player and upscales DVDs in fine style, too. You'll still have two Blu-ray players that'll give you lossless audio with 2D Blu-ray discs. And if you're only going to watch the occasional 3D film, you'll be saving yourself hassle and money.
Maybe I'm just a cheapskate!
B
BIGBERNARDBRESSLAW
strapped for cash
417
BBB, no offence taken. My forum name says it all really!
BB, since 3D films will comprise less than 1 percent of my viewing, I'll settle for PCM and the limits of digital optical. If I get a taste for the third dimension, I can always get the wallet out later!
B
BIGBERNARDBRESSLAW
No offence intended, I could be SFC2.
I'm no 3D fan either, but I thought it would make sense to get a dual hdmi BDP now before they become extinct, and I have to spend loads more on a compatable AV Receiver.
I know I'm getting a free 3D player with my tv, but if I sold it and my BDP-320, the net cost wouldn't be very high at all. It's not a 100% decision though, I'm notoriously indecisive.
strapped for cash
417
You're probably right. In the not too distant future there'll be no such thing as an affordable BDP with twin HDMI outs.
Not wanting to part with my Denon 2500BT was a big factor in my decision. If I hadn't got the free BDP I'd probably have bought a Sony 790, but there's always ebay further down the line. I'm content to see how I get on for now. Incidentally, did you check out the Panasonic 120 review I linked to on another thread? If not, here's the link again:
http://forums.hdtvtest.co.uk/index.php?topic=7206.0
That pretty much sealed it for me.
B
BIGBERNARDBRESSLAW
It's a decent review, and those guys know their stuff.
I think I can raise £100 plus if I sell the Pana 120 and Pioneer 320, so half of what the Sony will cost.
WOW!!
I've just seen the price of your Denon when it was new, this must be why you don't want to let it go.
I won't say what I was about to then.
strapped for cash
417
I bought the Denon second hand for £170, which in my view was an absolute steal. I also think it's an astonishingly good player (or transport, to use Denon's terminology).
It's built like a tank, so should keep going for some time yet. There's always the fear that Denon will stop releasing firmware updates for older players, but I'm yet to find a Blu-ray disc the 2500 won't play. It's silent in operation, too, which for me is priceless.
B
BIGBERNARDBRESSLAW
Good price in comparison to the RRP, and cheaper than one on ebay now.
I'm stopping typing now, the drink's kicking in, and I'm forgetting exactly which thread I'm posting on.
strapped for cash
417
Yes, as far as I can tell, the last firmware update was v 1.122. That said, I've not encountered a single disc that won't play, and I own more than 250 Blu-ray titles. Apparently I'd have difficulties with Cowboys and Aliens, though :O
AnotherJoe
407
I'd suggest getting a Panasonic BDT310 with twin hdmi from ebay (£139)
http://www.ebay.co.uk/itm/Panasonic-DMP-BDT310-Blu-Ray-Player-DMP-BDT310-DMPBDT310-/290789908250?pt=UK_AudioTVElectronics_Video_DVDPlayers_Recorders&hash=item43b46ddf1a
AndrewFG
44
bigboss said:
If you get a blu ray player with twin HDMI outs ... you can use your existing AV receiver for audio & send 3D images directly to TV.
Does anyone by any chance know if, with the twin HDMI connections, the HDMI CEC function would still work? So that the Receiver and the Tv will both select the Blu-Ray player when it is turned on, and the Receiver selects the TV optical out when the Blu-Ray player is turned off?
