B
BIGBERNARDBRESSLAW
I've no idea, but I have the same amp as you, and I knew nothing of this function before you mentioned it, so thanks, I'm going to try it out.
BIGBERNARDBRESSLAW said:Oh, it's a tv function.
BIGBERNARDBRESSLAW said:... presumably the commands will still travel down the line, so in theory, it should.
bigboss said:Just use a Logitech Harmony remote. 🙂
AndrewFG said:bigboss said:Just use a Logitech Harmony remote. 🙂
I bought one of those once. It broke within two weeks. I was not impressed...
bigboss said:What's your budget?
AndrewFG said:2) The Sony STR-DA2400ES Receiver does not support HDMI 3D pass-through; nor can it decode the audio part of a 3D signal.
AnotherJoe said:The STR-DA2400ES will decode the audio fine - I suspect you havent set the blu-ray up correctly.
AndrewFG said:2) The Sony STR-DA2400ES Receiver ... nor can it decode the audio part of a 3D signal.
AnotherJoe said:... just moaning about HDMI-CEC ?
AndrewFG said:AnotherJoe said:... just moaning about HDMI-CEC ?
I think you are being offensive. You did not read my post properly, and you you seem to be criticising me for something that I did not say. My post was merely giving feedback of my findings. Thank you.
AnotherJoe said:... as you clearly dont appreciate my help ...
AnotherJoe said:I was just checking that you'd got the 3D picture and lossless sound working ok.
AnotherJoe said:... I'll just say the CEC will work with the right combination of settings - and leave it at that.
AnotherJoe said:AndrewFG said:2) The Sony STR-DA2400ES Receiver does not support HDMI 3D pass-through; nor can it decode the audio part of a 3D signal.
HDMI 1 to TV, HDMI 2 to AV.
Then you have to turn off the video for the 2nd hdmi. On the Oppo I think its called Split A/V
(page 53 of the manual)
I have to do a similar thing with my Panny310/Sony5400 combo.
AnotherJoe said:... it does work using the remote for the TV and the AMP. For example using the TV remote - I turn on the TV, select tools CEC amp and the amp turns on, select CEC player and the BD turns on, and the amp switches to BD input, and I can control the BD+AMP with the tvs remote. When I turn off the BD the input sticks on HDMI2 but pressing channel up/down fixes this and it changes to TV, and the amp changes over to TV optical.
AnotherJoe said:... better still is using the remote for the amp which I think is practically the same remote as on the 2400. You may or may not have to program it with the correct code to control your TV and BD.
AndrewFG said:No luck unfortunately!! The DA2400ES remote control is not programmable (so it is not "practically the same " as the one on your your DA5400ES). Therefore this cannot solve the problem for my case...
I am starting to feel that something is pulling on my wallet...
AnotherJoe said:Make sure that only "TV" is set in the HDMI settings menu on the amp - rather than "TV+AMP" .
If you use the AMP's remote as detailed in above post you shouldnt have any problems.
If you change CEC settings on another box - you may find the amp has the setting back to "TV+AMP"
