Sony BDP-S5000ES
ok thanks, I thought it would be but thought I would ask. What price range or players you can recommend to fit my system ? I've been looking at the Sonys as most of my system is Sony, but would consinder a different make.
Ronald Archiebald
63
EvertonMonkey,
A Sony BDP-S760 if you need analogue outputs and Wi-Fi.
Alternatively, a Sony BDP-S370 would also do nicely while offering you some other functionalities.
I am assuming that 3D isn't an immediate priority for you.
Ronald
Ronald Archiebald: A Sony BDP-S760 if you need analogue outputs and Wi-Fi.
Ronald Archiebald:
EvertonMonkey,
Ronald
Any reason why the BDP-S370 and not the S570 or S770 ?
Are there any other players upto about 600 coming out soon ?
sonycentre
50
I would go with the bdps370,it's a belter for the money.i have the bdps470 for 3d blu-ray films.But paired with your w4000 tv the bdps370 would be a perfect combo.
sonycentre:I would go with the bdps370,it's a belter for the money.i have the bdps470 for 3d blu-ray films.But paired with your w4000 tv the bdps370 would be a perfect combo.
But why the S370 over the S570 and S770 ?
Ronald Archiebald
63
EvertonMonkey:
If you intend to upgrade to 3D, then by all means go for the S570 or the S770.
Otherwise, the S370 will more than suffice. With each passing day, I only get more and more impressed with all that this machine has to offer.
A brilliant effort from Sony!
