hey guys
I've just got the new Sony STR DA 2400es after a long wait for its release (no idea if mine has the shy hd bug-fix but dont have skyhd yet) and it's not doing all it said on the tin. I'd really appreciate some ideas on this one...
My set-up:
PS3
Infocus IN82
Pioneer Laserdisc player
Kef 3005se Speakers
Sony STR DA2400es
Understanding Missus
I've got a PS3 connected via HDMI to the BDin HDMI input of the receiver. A 15metre HDMI out to my projector (the only cable I have long enough to span the room)...all as per the diagrams etc in the manual. having struggled to actually see the PS3 picture for ages, I changed ps3 output settings I can watch and hear discs thru the ps3 with only an HDMI link from PS3 to Receiver...but the projector (Infocus IN82) takes AGES to set up the image and display it.
BUT:
spent all day with it and:
A) I can't see the GUI. saw it once, not sure how or why it suddenly worked..auto calibrated...and never again. Cant access it at all now. replaced a cheap HDMI cable, but the little HDMI indicator on the front still flashes intermittently sometimes making me wonder if it's a faulty connector issue? thing is tho its displaying the blu rays and audio now with no issues so im not sure it can be...but the GUI just wont come up having pressed all the appropriate buttons on both remotes. Ideas? is there a setting I have wrong?
B) I wanna watch Laserdiscs...have got the LD player connected to the Composite video 1 input and have switched Video 1 to composite mode in the menus (it clicks over and over until that setting is changed correctly so I'm guessing that at least is correct), also changed resolution to 1080p for upscaling (tried all the settings on that front actuallyI think), but it still wont display video. I can hear the stereo signal from the LDs through the speakers and listen to the films, but the video won't display. according to the table on p32 of the manual it should take a composite image via Video1 input (also tried with composite dvd, sat and bd inputs), upscale it and send it on through via the HDMI output (the only 15 metre lead I have as I mentioned), but It's not having it! I don't wanna have to run ANOTHER cable up through the cupboard, through the loft and down through the ceiling into the projector when I've already spent over £100 on an award winning 15m HDMI cable specifically to deal with ALL the upscaled video...and the LD player ONLY HAS composite out video (Red White and Yellow or Scart), so there's no other option coming out the back of that either.
Do any of you guys have a clue where I'm going wrong? Do i need to switch upscaling off of the PS3 (should that effect the LD signal?) I'm happy to reset the receiver to factory settngs to start again...but could do with some pointers.
I also wanna connect the Wii and another DVD player for region1 disc playback (unless anyone knows how I can play R1 discs in my UK PS3???), but with the basics on the blink I thought it prudent to sort this before complicating things any further...
Any help would be hugely appreciated
Many thanks if you've read up to here all the same!
My set-up:
PS3
Infocus IN82
Kef 3005se Speakers
Sony STR DA2400es
BUT:
