Sony 2400ES and Connection to Castle Sub Woofer
Yetholm
9
I have recently purchased a Sony 2400ES Receiver. The sub woofer connection on the Sony is noted as monoaural-single connection. The sub woofer has a right and left line input. Is there a cable which will link the two devices or are there other alternatives?
Gerrardasnails
295
slewis:I'm in a similer situation, just connect it to the left input on the sub & it should be fine.
It's not a situation or an issue, you just connect from the receiver to the sub, either left or right.
