Hi
My house isn't actually big but does have some fairly solid walls. It's a victorian terrace, and I get 40mbps in the livingroom at the front of the house. I have a Connect:Amp there, ethernet connection to my router.
I have a Play5 in the kitchen, and another Connnect:Amp in the master bedroom (directly above the livingroom, where the router is).
Due to the walls, I was getting only 1.5mbps in the kitchen. So I bought a TP link power line adapter, and it's been great (now get 35mpbs). It's got the same name/password as the router, so my devices pick up the strongest signal in the house as I walk around.
Unfortunately, the Sonos chooses either the TP Link cloned network or the router (SSE, Technicolor, not that it matters), and starts the mesh from that wifi signal.
If the mesh is started from the kitchen Play5 (on TP Link), then when I'm on the router in the living room, it cannot "see" the sonos (and vice versa). So I need to go to the kitchen, wait for the phone to pick up the TP link, and then change music.
I know I can connect to the SonosNet as a source of wifi, but that's very weak (3-5mbps).
I know Sonos doesn't support Powerline adapters (a shame they cannot find a solution, as I expect there are many frustrated customers).
What I wanted to know is there any way to get good wifi throughout my home, AND be able to connect to Sonos without it being a PITA?
Do I need to buy some new kit? A better wifi system (one of those Google Mesh things?) Or eBay the Sonos and buy something else?
I'm about to undergo a massive building project (which will involve some re-wiring), so wanted to try and resolve this issue once and for all.
Cheers,
BA
Unfortunately, the Sonos mesh will sta
Cheers,
BA
