Some wiring questions - spades or banana plugs
Hi all WHF readers and WHF team!
I am 20 years old student and I am trying to get myself in hi-fi (or at least come near it, because of the budget).
My father had Technics equipment since 1970s and so I have it also (newer stuff).
In the beginning of this year I bought myself an amp: SU-A900D (pre and power SU-C800U and SE-A900S) and speakers: JBL Northridge E80. (There is also a CD player which I will replace in the near future, a tuner, TV, PS2). With the speakers I bought Van den Hul CS-122 speaker cables without terminations (our biggest hi-fi dealer does not have a termination machine).
Because I always want something new I decided to replace the interconnects and bi-wire my system. So the first question is:
Which interconnects would you recommend for upto 15 pounds per piece? I was looking at
IXOS XHA215-100...
And second one:
I was looking at QED Silver Anniversary XT Speaker Bi-Wire Cable with terminations... I think the cable is very good in this price range, but I don't know if it is better than my VDH (just looking at the price/m)? So, should I buy a second VDH cable, or should I choose QED bi-wire cable? Or should I choose something else (in this price range)?
If I should choose QED cables, which terminations I should take? QED offers airloc banana plugs and spades... I know my speakers can connect with both.
When bi-wiring, should I connect through A and B terminals on my amp, or should I connect everything thorugh one terminal?
Sorry for any mistakes in pronouncing (I am a foreigner, from Slovenia :) )
Thanks in advance,
Nejc
I would maybe spend a little more on interconnects JoelSim put me onto the VDH d102 III for a bargain price here.
or if you don't want to go over £15 look up gotham interconnects on ebay.
The VDH and QED cables are completely different. The VDH produces an open, warm sound and the QED is clinical, bass light and bright. I personally dislike the QED sound and I find VDH and Chord cable to suit my needs.
Spades provide a better, more secure connection than plugs, but unless you are high end there is no difference.
Do you have 2 monoblocks?
ÿ
ÿEdit: Sorry Andrew, thanks for fixing that.ÿ
Thanks for your reply!
Is there an easy way to know if there are 2 monoblocks? Or do I just have to open up my amp?
Thanks,
Nejc
Ah I misread your question I thought you were on about bi-amping.
In my opinion bi-wiring is not worth it. It's a pretty split subject and the argument is an old one so people generally just decide for themselves. I see it as a way for the cable manufacturers to make money, as people get it confused with bi-amping which does make a difference.
So to answer your question it depends. Bi-wirable cables use one plug at one end and two at the other so you would simply connect it as usual. If you are using 2 single runs of cables just connect it to A+B and select A+B.
ÿ
BTW: I wasn't suggesting you take your amp apart, unless you know what you're doing!
ÿ
No. It is just one amp (for now).
I am ceratin that there must be a diferrence betwen one amp and bi-amping. So (a non expert conclusion) if I have an amp, which has 2 terminals (that are independant??? <- I don't know), there should also be a diferrence if I put high frequencies through A terminal and low frequencies through B terminal.
But I am sure that there is no diferrence with bi-wiring if I connect low frequencies and high frequencies on one terminal together (let's say A) and then connect it to the speakers as if I was bi-amping (then it is better not to spend money and use those golden jump plates on speakers and use single wires).
I was not trying to open my amp.
I am not an electrician!
Thanks,
Nejc
The amp doesn't suddenly double in power, it shares the power.
It's the same as if you were to fix 2 cables to one binding post using a spade and a plug.ÿ
The option that I have chosen is to replace the metal bars connecting the terminals of the speaker with good quality jumper cables.ÿ
OK! Thanks for all your replies and suggestions.
I think I will then give the budget I gave for speaker cables to interconnects.
Is buying a good quality jumper cable a common thing? (I mean do people do that or are they mostly satisfied with metal bars provided with the speakers?)
The general view seems to be to replace the metal bars with proper wire interconnects on the speakers.
ASK THE COMMUNITY
