professorhat:
Geesus:Could i just add a word of caution to people updating firmware. Firmware is best updated when the equipment is connected to a ups (uninteruptable power supply) as any power outage,brown out or glitch could possibly turn your nice shiny blu ray player or whatever into a nice shiny big paperweight.
Fair enough in a company's server room, but very few people have a UPS at home. And there's no justification for buying one just to update the firmware of your Blu-Ray player - how often have you had a power cut in the last year? If it's more than once (assuming you are in the UK of course!), you've been unlucky. So the chances of having one at the point you are updating are ridiculously small. You are far more likely to be run over by a bus which, when you think about it, is far more serious than having a broken Blu-Ray player. But that doesn't stop you crossing the road does it?
Geesus:Not wanting to scare anyone but it does happen from time to time and sending back this equipment may not be an option if the company knows what has happend.
There's no reason why a company wouldn't fix a unit which has been 'bricked' because of a failure of power during a firmware update. They can easily flash the firmware chip to get it working again. If it's outside the warranty period, you run a certain risk, but it would be very bad PR for them to not do it considering the simplicity of the fix. Of course if you are trying to put a non-official firmware upgrade on there (e.g. the PSP one which allows you to play copied games) then you may well be on your own. But for an issue upgrading offical firmware, there shouldn't be any reason why the manufacturer won't help you.
Geesus:Also dont be in a huge rush to update firmware if your player is working ok.Hasty updates have also been known to break certain things and it`s always best i find to let others test firmware out for a while before i update mine ; )
Can't argue with this - if everything is working as you want, there's no need to update. However, I've found Blu-Rays now load a lot quicker thanks to this update on my Sony so I would say it's definitely worth doing in this particular instance.
Sony's
Terms and conditions make interesting reading.
