- Aug 10, 2019
- 2,556
- 5
- 0
Hi
I'm thinking of getting a new plasma and the room it will go in will not have the Sky+ box in as that is in another room so I'll have to connect it via the wall-plate that is fed via the powered distribution box in the loft. This will mean relying on a RF connection using coax cable to get Sky into the plasma.
Just wondering if this is a big issue? I've been told that I really should try and get the box itself physically connected to the plasma so that I can use a Scart connection at least but this will be impractical for now.
Is it something to worry about or more a case of 'this is what you should do' where the difference will be hard to see?
